Electric retracts have also been known to put airplanes into a lockout situation because of to much amp draw. Which is why I use a separate battery for my gear only.
Are you sure it's not that Futaba radio system your using frank? ;-)
I went with the H9 corsair because of the scale outline factor among other things. But that's my preference. If you don't care about that, it's a great airplane. The Robart gear is actually pretty good, I may end up buying those for my build if sierra never makes me a set.
