The metering needle lever must e the problem. I bent it down until it is level with the carb body and now I get no gas thru. The motor wont even pop with the choke full on.Before I donked it I would choke it until gas dripped out.(inverted motor) Then it would start right up I can't get it to drip gas at all now.
The diaphram was good before, I don't see why it would be a problem now>
Any other ideas?
