As you can see in the pics above, every component was neatly wrapped in foam and then individually sealed in its own plastic bag. In regards to the finish, the pics of the airplane we all seen initially does not do the finish justice and I fear that the pics I took doesn't either. I can tell you first hand the finish on the airplane is very and I will add another (Very Nice) also the colors in person are really vivid. The plane is painted out of the mold so there are no seam lines.
Next I decided to slide the parts together to see how things fit and lined up and this is where if I wasn't already happy with the finish I really got happy.The wings slid on the tube and snuggled up next to the fuse easily and perfectly. Next came the stabs, same thing, tubes fit perfectly not too tight not too loose but just right..
I am really looking forward to getting this model going.
