RCU Forums - View Single Post - Good servos for servo recoil and elevation
Old 11-26-2014 | 09:04 AM
YHR's Avatar
YHR
For elevation I use gear retract servos. Strong, and slow they allow for fine movement.
Freaky has a point. It takes a lot of effort sometimes to get a servo recoil in place, and when it fails it is a lot of work to get at it to replace it. Might be an idea to invest in a quality servo with metal gears for recoil. Run that barrel headlong into an unmovable object and the weakest like could break. On a low cost servo it migh be the tiny nylon gears.
Having said that I use cheap servos with tiny nylon gears for recoil, and have only had a couple of issues.
