Originally Posted by
strmnd54
I'm planning to use servo recoil and servo elevation with a 12 wires slip ring in my panzer IV turret...
I will use a step down voltage regulator adjusted at 5 Volts to power the servos and just send the servo signals through the slip ring: Meaning 4 wires( positive, ground, recoil signal, elevation signal)...Hope it'll work.
The 12 wire slipring worked fine with servo wiring and with TBU wiring. Used a common ground and positive for servos at full battery V, but your approach to use reg. 5V is better.
Ran power for BP firing gun through a single set of slipring wires. Measured 4A spike at 7.6V. Slipring was fine, but the current surge was very short – the fine nichrome wire used as an ignitor blows like a fast acting fuse. Ran many shots thru the slipring, but still decided to run separate wires for the gun to prevent damaging the slipring.
