Originally Posted by
Truckracer
+1, dirtybird, don't close up that fork where it engages the needle valve! As speed said, it only has to hold the needle shut when required and allow it to open (not pull it open) when the lever removes the seat pressure as the diaphragm moves. At this point it sounds like you may need a new metering lever to get back to original configuration.
