RCU Forums - View Single Post - Novarossi R26CR
Thread: Novarossi R26CR
Old 12-03-2014 | 04:13 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Originally Posted by särpet
I copy this information from enya.30 thread.
These are all having the engine peaked just long enough to get a number then I let it run for 2 minutes 400rpm rich of peak.9x5 - 13,560rpm
Why you use so much oil?
More oil less power.
Ithink 1l fuel is enough runing in time the enya abc engine.
That figure you referred to was after about 1/2 gallon of fuel from new on the test stand. Read the bottom of page 1. The 13.5k was on a nowhere near broken in engine.
More oil = more lubrication. I've found my engines run a bit faster on more oil; the Enya 30 included. More oil, better piston seal.
1L of fuel for break-in on the bench may be fine, but it will take gallons for that AAC Enya to really open up.
