This morning I did find a laser cut ply piece that appeared to be the aileron horn jig but when placed even with the root end of the aileron the slot is a inch or so too far to the inboard side of the where the horn should be. I was able to easily find the slot in the left stab for the large control horn. I have not found any indication of where a rudder hardpoint might be located. I will try using what I thought was the aileron jig....that may locate the rudder horn? The ply parts included a rudder servo tray that fits perfectly in the forward (bottom wing area) area of the fuselage. Pull-pull cables are included as well.
I would like to know for sure at some point what is the Akiba recommended incidences, thrust and CG.
-mark
