Originally Posted by
njmheli
Hi All.
Have just got my tail gear installed and completed the tail wheel doors ,so starting to catch up a bit now............I decided to link the tail wheel doors to the tail retract unit ( I did the same sort of idea on my P-47 ).All appears to work well,with very little extra load on the electric motor !!!
I had to re-spray the tail wheel doors as I found that the paint had very little "key to the plastic", I found out when I was doing the main gear doors etc........alot was just flaking off after the cutting etc.
These are a few photo's of my set up :
A short video is here :
www.youtube.com/watch?v=vQj5Z0KuUh0&feature=youtu.be
Regards....................Nick (UK)
Great job. Are you using the Robart actuator? Your cycle speed is about 4 or 5 times faster than my setup which is using the Robart actuator.
