Originally Posted by
Ramstein44
1. Open it up. Unless you're making the hatch form fitting exactly. I've always had to add supports to the gun hood to get them to sit correctly to the fuse.
2. Mold into the fuse
3. All I'd care about if you wanted to do the work would be the addition of panel lines.
JMO
The hatch will be as close to form fitting as possible.
Panel lines would Definitely be on the plug one way or another, same goes for hatch's... Rivets arent really that big of a problem either. Lithoplate takes up time, but its not out of the question.
