RCU Forums - View Single Post - Removable electronics
Old 12-06-2014 | 07:24 AM
YHR's Avatar
YHR
Default Removable electronics
On another thread I talked about setting up your electronics so they are movable between tanks. The thought being once you have acquired multiple tanks does it really make sense to have an expensive electronics package in each one.
I had a request from a customer to make this process a simple as possible for him. So I mounted a complete Battle Armor package on to a removable board. All you need to do is plug in the end devices, and you are ready to go. This set up( with the receiver attached) can be moved around and placed in any stock Heng long tank. Once you plug in everything you then have a complete IR battle tank with 15 watts of TBS sound all controlled by a Hobby grade radio. NO soldering just plug and play
Time to install this in a tank would be less then 5 minutes.
I showcased the Battle Armor stuff, but the same idea could be used in any set up.
ID:	2052635   Click image for larger version
