you will also need the UBEC's I linked in your other post or the receivers
WILL burn out
The TEU104BK Tamiya includes puts full battery voltage(over 7 volts) into the receiver where it is made to take 6volts max
Also you have to do a little modification to the plug that goes into the radio basically pop the red wire out of the 3pin connector
Basically it will look like this (pic of my hornet)
notice how the red wire going to channel 2 is disconnected (I cut it on this one but you can pop it out and tape it)
UBEC goes to the battery port which is the top
Note the UBEC you would get(the one I linked is the same one I just pulled the sticker off) won't need to be spliced like that. I had to cut the wires cause I was using it for something else prior, and cut off the connectors. It actually has plugs that plug right into the ESC, and receiver
http://www.rcuniverse.com/forum/rc-e...l#post11931960 read that it has links to what else you will need at a minimum outside batteries
