To answer do I need expo on an LT 40 if you don't have shaky hands then no probably not.
Expo will make your control movements less effective at the center of your stick. In other words if 10% of stick movement equals 10% of control throw. Expo will change that to less control throws. Or more control throw depending on which way you set expo. Generally expo is used by larger aircraft with big control surfaces.
