Hi Al,
If the 6XAS is brand new, then it comes with all the defaults aleady set. This is your starting point for all control surfaces.
You will need to make sure that your control surfaces are physically set to as close to perfect as you can get them, and then if there are minor adjustments needed, you can then change the ATVs. Trims, and Subtrims where needed.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (
http://www.futaba-rc.com)
