RCU Forums - View Single Post - Built in roll in horizontal stabilizer?
Old 12-09-2014 | 01:10 AM
serious power
Originally Posted by OhD
If I line up the elevators tips with the stab tip trailing edges, one elevator is well above the other at the root. In other words it looks like they do not have the same incidence.
Jim
Hi Jim,
That would seem to be as Tony has said.
You might be lucky in that it is obvious, otherwise you might have a little twist and not realise it - a heart-breaker !!
It can be quite tricky to measure incidence on a tailplane with pre-installed elevators and Oxai stab halves are not independently adjustable.
Oxai are generally good at replacing stuff like this.
Brian
