Hi guys:
I have read through the sections on ailerons and still have questions regarding what might be the best hardware arrangement to use for joining the upper and lower ailerons, considering that I will have to remove the wings for transportation. Also, where do you place the joining rod between the upper and lower? Is it in line with the servo pushrod or is it offset?
On another note, what is the best engine size for the 1/6 scale, 91 or 100? I'm thinking Saito 91, but since I haven't purchased it yet I'm still open on it.
As always I appreciate the help. Thanks.
