Hi Guys,
thx for your kind words.
My idea is a) to let it look nice BUT also b) be able to see more or less everthing (connectors, etc.).
Josh you looked carefully :-). You are absolutely right. This is the smoke-tank and for that I need a lot of fuel comming out the tank. Because it is not easy to use the CARF tank-plug with a 6mm tube I use 2x4mm. The clunk looks like attached.
If you want Josh, I can give you a dropbox link with all building pictures. Please send me an email to '
[email protected]' if ou want.
Best regards
Phillip
