Originally Posted by
init4fun
Thank you hsukaria , and in my opinion , any talk of any kind of Escapade oughta be ok , course I am not any kinds of "thread purist" and consider ALL plane talk worthy of being printed
A couple of things i forgot to mention were that I went with nylon bolts on the landing gear as well as a decent set of DuBro rubber wheels . I also went with the optional two servo setup on the Ailerons rather than the single . I realize it's twice the weight , but with the sealed hinges one servo seemed to be slower in full left to full right stick maneuvers than the dual servos are . Even with the on board glow I still came out a tiny bit tail heavy and chose to add extra nose weight in the form of a brushed on coating of thinned down epoxy to all exposed wood of the firewall and cheeks . I do this to every glow or gas ARF I have and have not lost one yet to the dreaded "firewall mush" that unprotected wood turns into after being soaked in fuel for a while .
Great thing about the thinned epoxy. I ended up having to repair the nose of my Escapade and went ahead and brushed the insides with thinned epoxy. I brushed Balsarite on the outside before recovering to seal and improve covering adhesion. Just watch out for the cowl cheeks flexing/vibrating, it will weaken the firewall glue joints. My firewall glue joints actually cracked due to the cheek vibration. I reglued with balsa tri-stock and added a piece of wood below the engine (same idea as Jeffie's bolt).
