Originally Posted by
C-Mack
Is there a tuned pipe to go with the TM928 that offers more top speed?
If you want more top speed then changing your gear ratio is the key...but of course if you have the same power output then it will take longer to get to that speed...
You can use different exhausts to enhance different engine characteristics...without knowing what you have or what you are trying to achieve then your question would be hard to answer...
