RCU Forums - View Single Post - Warbird Champioship Event
Old 12-10-2014 | 12:38 PM
  #74
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Originally Posted by airraptor
how will a molded wing tip work on a foam balsa covered wing. The wings tips will be different between the different building techniques..
Jeff, what I plan to do is tape off the wing exposing the last 3/8" or so. then sand the balsa to the point where the tips slip fit on then epoxy in place. I will then match sand the balsa sheeting flush to the tip. When the wing gets glassed the glass will extend past the seam. Prim and paint the whole wing. It would not work well if using film covering.
