Tbm dv8r
Hey Guys, finally getting around to finishing up my TBM DV8R. Decided on a two piece wing, therefore, I glued the wing tips to its separate main (half). My problem is the bolt that threads through the carbon and metal spars in each half. About an 1" or so sticks out of the wing after screwing it tight into the wing. Did you guys cut it off at the leading edge or "WHAT" did you do with it? I do not want to leave it hanging out. Thanks, I know I am still a rookie so I am certainly asking for your help and advice. Chic
