Originally Posted by
Leroy Gardner
Geometry is the key to a pull-pull system , the length of the control horn and the dual servo horn have to be the same width at the attachment points with the rudder attachment on the hinge line and a straight servo horn. If there is off sets in one there has to be an off set of the same amount in the other and the cable tension will always be equal. Simple as that.
Leroy
