Jeff,
It's been so long since we had a 10GX mounted in that airplane that I've forgotten what setup we had. If you remove the center section, you will lose some performance. There are alternatives in the market for side-mounted Pitts-style mufflers that you may be interesting in checking out as well. Have you tried adding an extension between the muffler and engine to make it clear the fuselage?
Jimmy
