I cut out the cowl tonight to the muffler in the standard position and it wont make any cut difference with the extension. Only thing would be the looks of the muffler sticking down lower. The bad thing is I would have to have a 30mm extension to clear the fuse bottom. If I would cut the center piece I would need to cut out 15 mm which would be close to half of its length.
thanks
Jeff
