RCU Forums - View Single Post - Demon Cortex Gyro question
Old 12-12-2014 | 06:50 PM
  #283
stevekott's Avatar
stevekott
Originally Posted by Scott Geller
I've thought about that but since I'm running (2) rx's I would not get the redundancy and defeat the purpose of the powerbox. The competition SRS does not have an sbus output either, which is another idea. Interesting thought though.
Scott
I would guess if that's the case then just use the wiring loom that comes with the Cortex, Take the five channels you want to stabilize and run those outputs from the PowerBox into the Cortex. Then use the A,B,C,D and E outputs on the Cortex to drive the servos. .. Good Luck .. Hope it works
