RCU Forums - View Single Post - Demon Cortex Gyro question
Old 12-12-2014 | 10:45 PM
  #284
Springbok Flyer's Avatar
Springbok Flyer
Originally Posted by stevekott
I would guess if that's the case then just use the wiring loom that comes with the Cortex, Take the five channels you want to stabilize and run those outputs from the PowerBox into the Cortex. Then use the A,B,C,D and E outputs on the Cortex to drive the servos. .. Good Luck .. Hope it works
Now that is exactly what I have been on about when asking about anyone using a Powerbox unit with a Cortex. Wish I could put it as clearly as you guys have just done. Scott, it will be fantastic if you could try Steve's suggestion and let us know how that works.
Cheers,
Jan
