RCU Forums - View Single Post - INSTALLING DUBRO HD HINGES !
Old 12-13-2014 | 06:21 AM
spaceworm
Originally Posted by Nogyro
Talk about resurrecting a dead thread. ... I am going to use the .047 music wire for a continuous hinge though. That makes for a real clean and bind free install.
I have used a continuous wire hinge pin to align the hinges while gluing and pinning them in place. If you insert the wire from the outboard ends and put a "U" bend in the end, you can stick the "U" bend in the stab end and secure it with a bit of CA. The wire then can be removed if needed for hinge replacement/repair and the elevator/aileron/rudder/flaps can be removed for transport/repair also.
Merry Christmas to All and to All a Good Flight.
Sincerely, Richard
