A friend passed away a couple years ago and I have a partially finished plane of his which I am thinking would make a nice winter project to finish up. I dumb thumbed my Sig Kougar a couple years back and I think this plane might be a nice replacement. The wing is tapered on the leading edge and about 58" in span. as you can see from the fuse picture it looks as though the glass cowl has been cut to take a piped motor of some sort. I would probably not got that route but until I know what it is I'm going to be hard pressed to know what he CG is and what the preferred power range would be. The mount looks like it would take a 45 motor or small case 60. The plan is set up for fixed tricycle gear.
