Guys thanks for the replies. I don't have the plan. What I think I will do then is pull the engine mount and rotate it 90 degrees so the head comes out the right side. I will fill the cowl with foam and then glass over the hole to fill the hole in the top.
I do have two long canopies. I think this thing should be a great flier. Do you think its worth putting a servo in each wing for the ailerons?
Any idea of what the control throws and CG should be on this?
Thanks for the help!
