So that's that job done
Now only have to mess about with CG cause she's tail heavy
If i need to add to much weight i will install the smoke setup/pump and battery for the extra weight and of course cause smoke's Smooookinnngggggggggg
- K140G
- Saddle tanks
- Full ducting
- 8411 in stab, rest DES 707
- Powerbox gemini 2 + 2x 2200mah for power
- Jet-1A gear 2 way......... (advise from my side, NEVER go for this option!!!)
- Jet Tronics valves
- Cat130 Hopper
Build was really an pice off P.. compared to my first one (green) every thing really fel together like Lego!!
One small
, the alignment of the wing bolds, that really Suc... big time...
Now waiting for an dry field, nice weather and some good luck.
For now crack on with the next one witch is already in progress, the magenta one
