Originally Posted by
speedracerntrixie
Just to add a little after the fact here. I have been able to remove a twist in a sheeted foam wing by jigging up the amount of twist required and using heat. Most times the adhesive whether it was contact cement or epoxy will take a new set after being heated up.
That is good to know. The wings were true but doing that could have added some washout.
