RCU Forums - View Single Post - please help this newbie out
Old 10-10-2003 | 05:51 PM
Balsa Master's Avatar
Balsa Master
Default RE: please help this newbie out
ok im not reading responses, but heres how id fix this.
#1 reslot the surfaces and use CA hinges. (down middle of surface for equal movement in all directions)
#2 IF i understand correctly there is a crack slightly to the left of the middle of the H stab if this is correct then id put a little peice of .5 oz fiberclass on it with CA and sand down. (top and bottom )
#3 again, fiberglass
#4 i agree wit replacing the covering, that little peice should be easy for even someone with no covering experiance.
# i think i missed #5...
#6 recover that part.
if its over a .40 i recomend expxy instead of CA for fiberglass
