Originally Posted by
zackS30
Well gentlemen, the Rc gods r looking out for me. My Grandmal from Indiana sent me a amazon gift card so I'm going to figure out how to use amazon and order a cc bec and a servo horn, the plastic on that comes with the spektrum servo bends all over the place.
Also another question, when I turn my wheels the servo only seems to turn to about 45° even though it turns to 90° I I adjusted my endpoint from 100% to 150% and it turns far enough to get the full steering range my wraith will allow but it doesn't stall. I hope that was the appropriate way to fix that.
As long as you got full steering, left/right, you should be good to go.
When I use a higher torque servo, an aluminum arm usually follows, if I can get one to fit, that's just my preference.
Yeah, some of those stock arms that come with servos are "soft". Hitec usually gives an aluminum arm with their servos.
