RCU Forums - View Single Post - Truggy Diff Oils
Old 12-17-2014 | 09:29 AM
EXT2Rob's Avatar
EXT2Rob
So it seems the majority of you run a heavier center diff fluid than you do on either end. Having a heavier center fluid makes sense in the previous post, that it'll keep either end from unloading. I'm pretty new to truggies, and mine is smaller than most of y'alls (it's an Ofna/HoBao Hyper 10TT, about 4.5lbs) and I have been using 5k front and center with 3k in the rear. Theoretically, what would be the effect in your truggy if you were running the same weight fluid front and center? I ask, because I wonder if I should go with a heavier center fluid. Thoughts?
