Originally Posted by
jjoos99
Can I install a tee fitting in the main carb line to fuel with? I know with a nitro carb you can flood the engine that way but wont with the walbro carbs it is ok. What is the deal with this carb? Can I get away with it without flooding the carb and engine?
thanks
Jeff
This carb isn't "pumped" like a Walbro-type. You could put a Tee in-line but with enough pressure you can push fuel through the carb.
I plumb all of my gassers with 3-line tanks (fuel dot/ fill line,carb line, and vent line) ,makes things simpler IMO.
