RCU Forums - View Single Post - Rubber Bands or Bolts?
Old 10-10-2003 | 09:46 PM
Spaceclam's Avatar
Spaceclam
Default RE: Rubber Bands or Bolts?
that is why nylon bolts are nice. they are impossible to pull apart, and when you hit something, nylon bolts are the way to go. they should however be replaced from time to time. they are also a lot lighter. brass bolts weigh more, but if your nylon bolts keep stripping because they are cheap ones, then a brass bolt will do you just fine
