I continue to slowly plow along building my Kadet. I got the fuel tank mounted and the holes for the fuel lines drilled. I'm using a Hangar 9, 11 ounce fuel tank. Got the servo tray installed and hooked up the Throttle and Nose Gear Nyrod. I spend a lot of time making sure that the nose gear works perfect and can be adjusted. Using a old JR Max 6 channel radio for servo installation. This is my shop radio used for building only.
