Originally Posted by
thnilsen
How have other builders secured the servo wires for the rudder/elevator to prevent chafing from moving around on the formers at the back of the fuselage. Its not very easy to get to the back of the fuselage to make any form of anchor for the wires, so I was hoping someone had come up with a clever solution that also makes it easy to perform maintenance on the servos if needed.
You can use some very lightweight servo wire tubes
http://www.f3aunlimited.com/gator-fe...-5-pack-gt1001
