All the bits and pieces have now been sprayed with 2 coats of polybrush.
I will go over all the parts and make sure no tapes need to be hit with the iron. I used all but about 3 ounces of the polybrush. This will give me enough to do a little touch up if necessary.
In the morning I will spray a good coat of the silver polyspray over the entire plane then give it a sanding with 400/600 paper. If all looks good a 2nd coat will go down then the color coat.
So far I like the products, sprays well and I gave the wing panel the pucker test and was unable to suck any air thru the fabric.
Here are a couple pics.
