cured glue
Hi . . .
Working on finding a glue suitable for filleting the glued joint while building a Kadet Senior.
Above line for who does not follow the thread or read back.
The Titebond III and Great Planes glues have now cured for 26 hours/
I think not much changes can now be expected.
I am looking at the size of any remaining solids after cure which I figure is a good indication of glued joint reinforcement beside the increased binding area.
The pictures are self explanatory for this purpose.
I now added two different glues; Gorilla and SIG-MENT. That pic is of the fresh application. We will see in 24 hours what happens with those two.
We may think that this filleting is somewhat equivalent to gluing 1/8" x 1/8" triangular stock in all corners which is not practical in a 90 degrees joint of stringers or a T joint or a doule T joint.(two stringers at 90 degrees with each other meeting a longerons).
Zor
