Originally Posted by
zrooster
Thanks vertical! For those with the XYZ 53, do you reckon it can swing that 24x8x3 dgiatr has on his or would you go with a different size/pitch? By the way, this thread is one hell of a good resource and I want to thank everyone for their inputs!
I am going to guess that is too much prop. For 50cc sized engines, there are 2 prop sizes that are standard. 22-10 for speed, and 23-8 for aerobatics. Generally the 22-10 is what is used. A twin configuration generally has slightly less power than a single. Then generally you go down one inch in diameter when going to 3-blade. So, going by this, you would be looking at a 20" or 21" x10 3 blade.
