Special Considerations for Short Up-Start Launch / Constrained Venue
>>High Reliability / Short Up-Start Launch Considerations?
So my at hand venue is a smooth, sandy seacoast beach which is often deserted in the Spring and Fall -- BUT, I also only have about 200' at low tide and sea breeze is obviously onshore.
The good news is that there may be some thermal possibilities due to differential land/sea heating which induces the seabreeze... plus there's likely a mini-slope effect near the dune line which seems worth exploring
The hope is that I only need to get 100-150' or so of altitude on launch to explore the thermal and slope possibilities. Am wondering if a shortened (100-150') Up-Start rig might do the trick for a 2.2m Parkzone Ka-8 that I just picked up... specifically considering the heavier duty version of the Up-Start from GP with the thicker tubing which is advertised for up to 100" wingspan (vs. the lighter "2m" version).
Are there any special launch considerations when using a short rig?... I don't think I need to go to high tension and, given that I'll be 'feet wet' at the release point would prefer to minimize risks associated with launching towards and over water... much appreciate any tips for achieving highly reliable launches by getting incrementally more comfortable. I don't think I can launch at too low a planned release altitude, if I'm going to have some room to abort a bad launch and get back over the beach.
>> PLAN B: Quadcopter Tow, or Lift & Release?
Another thought I've had for this venue, is to use a stabilized quadcopter to aerotow or lift the Ka-8. Most of the Youtube vids that I've seen have been a bit horrifying -- usual approach has been to drag the glider up vertically by the nose with a 'drop' release from pure hover. Best outcomes have been flyable but only after a big loss in altitude due to recovery needed... and then there's the crash risk from entanglement of the towline in the quad's blades.
I expect it might take a fair amount of practice for a team to establish a nice aerotow profile with a quadcopter -- would need to be smooth to avoid gyro induced oscillations... and might be something best done with wind as this could enable a protocol where the quad pilot maintains near zero ground speed and can focus on the ascent dynamics.
The need for two accomplished pilots (something I won't have often), for me, seems to argue for mounting the glider on the quad with CG aligned and flying the quad in a forward climb by making use of the glider aerodynamics principally for lift -- sort of a quad-assisted take off, or perhaps. a winged-quad concept. Release likely makes sense at altitude with the quad in level forward flight at a modest airspeed in the range of that for hand launch of the glider.
Given that we're exploiting lift from the glider's wings, a pretty modest quadcopter might be all that's needed -- indeed keeping the quad's blades near the wing roots so the rest of the wing can fly in relatively undisturbed air would seem to make sense (vs. brute force). I'm also speculating that control over altitude and direction could be substantially controlled by the quad -- so from the perspective of piloting the quad, this really would be the equivalent of putting a pair of wings on the quad -- something I might be able to practice initially with some spare free flight wings.
Welcome any thoughts, experience, comments that folks might have on either the short Up-Start or copter launches (multi-rotor or helicopter?)... or other approaches to getting my Ka-8 up off the beach, while avoiding landing out -- as in -- LOW (on the water without floats ;-) )...
