RCU Forums - View Single Post - Problem with Transverse on Tamiya Sherman
Old 12-23-2014 | 11:15 AM
sevoblast
Originally Posted by dlobmwm3
Still no joy fellas. Something is going on that I can't put my finger on. The Hobby People radio is not functioning as expected based on the plugging the number in the appropriate areas. The right stick has to be moved left and right in order to go forward and backwards vs up and down to move forward and backwards. I also cannot get he fire button to work. But once I plug in a Futaba 4YF everything works except the turret moving left. consistently even after reprogramming it. The left stick has to be moved to the left very slowly for the turret to transverse left. Otherwise if you move it fast to the left it won't work. This does not happen in my Tamiya Panther G. Bad DMD and MF?
Disconnect the traverse unit from the DMD. Try a separate electrical supply and see if it works sans DMD/MFU with the turret in place and sitting relatively level. If it does not work, get a new one. If it does work in both directions, you may indeed have a bad DMD or MFU.
