RCU Forums - View Single Post - Do you like your Pizzaz???
Old 04-30-2002 | 04:40 PM
davham's Avatar
davham
Default Do you like your Pizzaz???
<<<DO YOU LIKE YOUR PIZZAZ>>>
No, not really.
I have a saito 91 in mine, while way unlimited vertical, wont do much anything good. Harriers are tough to do--wings rock too much. Mine wont tourqe roll worth a hoot either. Wants to fall off either side quickly. I have no good way of weighing it. I have added some down thrust and moved the cg back to just shy of 4''. Flew it today and seemed a little better. I was able to remove most of the mixing for knife edge flight and inverted it stoped diving hard. I had read some people moving the cg back as far as 4 1/2---4 3/4. Going from 3 1/4 to just shy of 4 sure woke mine up as far as elev response. Pushrod must be flexing when doing the wall, I have a dave brown fg one to install some day. I used light foam wheels and mini servo's to help keep weight down. I guess I'll remove the aluminum spinner and move the cg back to 4 1/4 and fly it again. If I make a hole in the ground before sorting this thing out, I wont be to heartbroken . Any thoughts???????Dave
