Originally Posted by
mnemennth
Okay... I stayed up WAAAAY too late last night...
http://www.rcgroups.com/forums/showt...0#post30187153
http://www.rcgroups.com/forums/showthread.php?t=2303442
Brian -
Sorry; I didn't make myself clear. I found on mine that the cheap plastic backplate on the included spinner compressed in use; allowing the collet to loosen up. This has been reported as the cause of several dead-stick landings caused by the prop and all falling off mid-flight.
I'm still using a collet-style prop adapter; I don't trust the set-screw type to deliver 600-800W of peak power
without stripping. I had to replace mine because it was cheaply made and didn't run true, not because I have any kind of distrust of the collet-style prop holders. You may find yours DOES run true and you can re-use it; but I would DEFINITELY get into a spinner with a metal backing plate rather than the plastic one like mine had.
I didn't know you had a 10" prop on yours; a 2 1/4" spinner is gonna look silly on it. A smaller one would be better.
Great... now it's my fault you need to build the plane that spinner goes on.
mnem
*Lunch Break*
Mnem - Took delivery from Santa yesterday of the aforementioned and sure enough, a plastic back plate. I'll maiden with same (mebbe) but replace soon there after!
ALL - I hope all had a wonderful holiday as did I!!!
All the best!
b
PS I was able to cancel my order from Amazon re: spinner!
