Originally Posted by
SyCo_VeNoM
I wouldn't use a fail safe as a good chunk don't work right with 2.4ghz radios. Also some newer radios have them built into the RX.
Throttle return spring is probably the only fool proof thing that will stop a nitro if it loses power.
As for remote termination of an engine... only thing I could think of is you would have to fit a 3rd servo on a controller with a 3rd channel to press something (like a piece of plastic) into the flywheel's rim to cause it to stop moving. You will need a fairly beefy servo though to do it, and concoct some rig. Or maybe some kinda electric valve hooked to the 3rd channel in between the exhaust manifold, and the pipe.
But of the shelf no nothing exists to my knowledge as it would have to be tailored to every single RC due to different setups
I dont know about that. Trying to stop a rotating mass spinning at 40k+ rpms will require alot of force from a servo and the engine internals will stress out. Maybe a servo blocking the exhaust will be a better option and cheaper.
krokodyl
ok so if i hooke up a random steering servo to make it touch the fly wheel which button would i use on the controller to make the servo do something?
If you have a multichannel transmitter and reciever you could use any channel thats not operating the throttle/brake or steering. For example if you have a third channel for the reverse or for a remote start you could pull those
