RCU Forums - View Single Post - changing 4wd to 2wd
Old 12-28-2014 | 04:46 PM
Barracuz's Avatar
Barracuz
Originally Posted by aminnich
I am not sure if this will work, but could you just remove the center diff, and just make it a regular diff? basically just remove the gear going to the front, also removing the driveshafts and whatnot
A center diff is no different to that of a rear or front differential. It transmits input momentum into ,usually, a perpendicular output force.
Most cars on the market are offered in both 2wd and 4wd setups. So If OPs car has a similar vehicle sold in a 2wd configuration it should be a simple matter of buying the parts necessary and installing them.
