RCU Forums - View Single Post - plane for sportman
Old 12-31-2014 | 07:47 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
I agree with Jester. The key would be to pick one, assemble it immaculately, spend the first 30 flights trimming it and get in lots of productive practice. Trimming is almost a lost art these days. Start with getting the CG set correctly. Both of those airplanes while in knife edge will tuck to the gear badly if the CG is too far back. If CG is correct then the tuck will be very slight. The remaining little bit can be mixed out. Get the ailerons moving EXACTLY the same up and down, left and right then add about 6%-8% differential. Set the throws so you have just enough to get through the sequence. Start off with 30% expo on everything. You may want to set up a snap roll flight mode. You have a positive snap roll at the top of an inside loop. Nail that snap and you will be head and shoulders above your competition.
