Sensitivity adjustment now available to beta testers in build #18, be sure to read the release notes for how the sensitivity adjust works.
Drac, sorry, yes, it starts on the first maneuver, which for AMA pattern classes is takeoff, but for F3A is the first actual maneuver and for IMAC is "Enter Box ..." As for the P-15 sequence, I'm not able to reproduce what you describe. Can you check that you didn't edit the pattern and remove maneuvers? the system DOES roll from the last maneuver in a sequence back to the first maneuver when you go "next" after the last maneuver since some people run the same sequence a couple of times in a flight (particularly the IMAC guys). On my device from 1/2 square loop with 1/2 roll down the next call is stall turn with 1 1/4 roll up, 3/4 roll down.
Peter+
Reason: Forgot to reply to drake
