RCU Forums - View Single Post - What the hell did I get myself into?
Old 01-01-2015 | 02:44 PM
Rapid13
I got the elevator and the rudder hinged today. It turned out better that I thought it would. I used the great planes center line tool and a #11 xacto blade for the slots and a razor plane and a bar sander to make the bevel. Everything is straight and even. I also glued the fuse sides. They look good but I did notice a couple of spots where they didn't fit together perfect and can see light through the joint. Can those spots be filled with thick CA? Also, I epoxied the wing bolt plate and firewall. The pieces don't fit together perfect but I figure they can be cleaned up later. Is that normal?
